This file 140708V7.UG5 file were does it go?, do I need to drop into one of the progs that you sent me or what
need input on this file .
Neil
Kiwi53 wrote:Hi Nick,
Thanks for that info, thourght you were talking about something else at first,till I read it a few times. Ok a ?, can this usb port be used for
loading a file to the controller?, I worked out that the larger usb port is for direct connection to the PC, networking not worked that out yet but this other
usb port can that be used also for transferring job file to be cut or engraved. Am I on the right track in thinking this.![]()
Neil
