140708V7.UG5
Kiwi53
140708V7.UG5
Post by Kiwi53 »
This file 140708V7.UG5 file were does it go?, do I need to drop into one of the progs that you sent me or what
need input on this file . 8-)
Thanks :D
Neil
Re: 140708V7.UG5
Post by waltfl »
hi marco
can you send me this upgrade file too,please.
my email waltfl13@hotmail.com
thanks walt
NickWL
Re: 140708V7.UG5
Post by NickWL »
It goes onto a USB memory stick, previously formatted as FAT32. This goes into your DSP (the socket on the left side, not the normal USB B that you send jobs through).
Then use DSP front panel option 1 (UDisk file) to do an update to the DSP.
Nick
Kiwi53
Re: 140708V7.UG5
Post by Kiwi53 »
Hi Nick,
Thanks for that info, thourght you were talking about something else at first, :oops: till I read it a few times. Ok a ?, can this usb port be used for
loading a file to the controller?, I worked out that the larger usb port is for direct connection to the PC, networking not worked that out yet but this other
usb port can that be used also for transferring job file to be cut or engraved. Am I on the right track in thinking this. ;)
Neil
NickWL
Re: 140708V7.UG5
Post by NickWL »
I don't know! I've been wondering the same thing myself but can't, at the moment, see the route through...
I've been having severe intermittent comms failure on both the USB 'B' port and the IP connection, so a third way in would be very handy!
Just keep plugging away!
Nick
Re: 140708V7.UG5
Kiwi53 wrote:Hi Nick,
Neil
You can use a USB memory stick to upload job files to the DSP card without PC required. It must be job file (data file with .UD5 extension). If you just uploaded LaserCad file (.pwj5), the DSP wont be able to read. So, you must use LaserCad to create the job file and save it to the memory stick then use the LCD control unit to read the file
Kiwi53
Re: 140708V7.UG5
Post by Kiwi53 »
awww thanks for that info, that will save me time sitting out side in the cold setting out
a file to cut or engrave :P an putting out side a good computer to use......hahahaha
Laser is not up an running atm still waiting for the Laser PSU to come then wiring the front
panel up. :|
Neil
