Backlash setting in Config/System setting for the speed I'm engraving at is not working as it should.
Marking at 125mm/s
Settings are not explained well enough in the manual to make sense.
Can you help me to determine what the following means?
Reverse Interval?
Offset Repay?
Do I use a negative number like the 708?
The manual is very frustrating!
