problem whith cutting ang engraving with lasercad
Hi! i import two or more things to cut or engrave to lasercad then they engrave or cut not in order. Some time they pile up (overlap, i dont how you say it in english) one over others, i have disabled re-order objects, but i still have the same problem, i also tried grouping objects, i use lasercad and x7, i need to engrave a jpg inside a box and do 100 of them.
Re: problem whith cutting ang engraving with lasercad
i also notice that the size of the cut is not matching the one i am working on lasercad.
Put it in different layers and you can set the sequence of cutting or engraving.
If actual size is different from what it seem on the LaserCAD, it means that you didn't fine tuned the 'um' yet. See "FAQ"
