Questions about wiring from controller to laser
Posted: Mon Aug 10, 2015 8:33 am
by Agent Sevan
I have been working at getting my obsolete software and hardware upgraded. I have managed to get everything from my old Kern setup running, moving anyway, and am at the step up pf firing up the laser, I think.
The laser itself is a Universal 60 watt Co2 laser with an Iota DLS 48-20 power supply (photos attached). Also attached is a photo of the wiring connection into the laser as well as screen shots of the OEM wiring diagram.
I am totally lost as to what to run from the TTL and PWM outs on the controller to the laser.
As shown in the connection photo, the only 2 wires connected to the 3 and 4 pins.
Can anyone help me get pointed in the right direction?
Re: Questions about wiring from controller to laser
Posted: Tue Aug 18, 2015 12:29 pm
Hello Agent Sevan:
It look like that the laser you have is not a regular CO2 laser but a RF laser because the power sources is DC48V, instead of high voltage laser power supply (LPSU)
What kind of controller do you have?
By looking at the block diagram, I think it is pretty easy to fire the laser by applying PWM output signal from the laser controller to PIN 3 and PIN 4. However, you do need to take care the Interlock and the other harness like the Key+ Key-. In most case, you may need to shorted this two pin to enable the laser, same thing happen to the Interlock.
I believe that by injecting +5V to the PIN4 with PIN3 to the ground, the laser will fire in full power.
It is just my though and you take the risk to do the test. I will not take any responsible should anything got damage.
Posted: Tue Aug 18, 2015 1:09 pm
by Agent Sevan
Universal Laser is the brand name of the CO2 laser that is mounted on my table. I'm using the AWC608 as my controller. I was previously on a Kern setup, which is all proprietary software and hardware. Excellent if you buy it new, but crazy expensive to join the tech support/upgrade club.
I have talked back and forth with a tech support guy at Universal and I'm about to make the big test.
I know there's another big question coming after she fires up, but I'll save that for then.
I have been documenting the upgrade and I'll make sure to share the links when it's all wrapped up.
Posted: Tue Aug 18, 2015 1:36 pm
What is the 48V DC power is used for?
Can you post a picture of the laser tube?
If it is a regular CO2 laser tube, then it must be water cooled and must be driven by a high voltage laser power supply which output as high as 26Kv for a 60W laser tube
