Default DSP Power
Axeman
Default DSP Power
Post by Axeman »
I'm just wondering if any of you guys know how to modify it. Mine got changed to 18% and now I'm trying to some lens alignment...but the power isn't enough to output a mark.
I need me some marking! :lol:
Re: Default DSP Power
Post by waltfl »
hi axeman
you need to tell a bit more what you wana do and what you have.
a picture or screen shot from your settings would help to help you out.
Axeman wrote:I'm just wondering if any of you guys know how to modify it. Mine got changed to 18% and now I'm trying to some lens alignment...but the power isn't enough to output a mark.
Axeman
Post by Axeman »
Ok, when you boot up your DSP for the laser...it has a power and speed setting sitting on the screen with no jobs running. That is the default power that fires when you hit the "laser button".
Mine for some reason changed from 35% to 18% which in my system...translates to 96% power to 10% power. Not a huge deal but...thought it might be a setting I over looked.
Post by waltfl »
hi axeman
usually this are the settings from the last work and it changes everytime you put a new file to work.
Axeman wrote:Ok, when you boot up your DSP for the laser...it has a power and speed setting sitting on the screen with no jobs running. That is the default power that fires when you hit the "laser button".
Axeman
Post by Axeman »
Yeah, mine doesn't change no matter what I run through it. Odd.
I may just reflash the firmware to see if it will kick it.
Users browsing this forum: Google [Bot] and 8 guests
