Were is the datsheet for the 4 axis board?
CNCMANIAC
Post by CNCMANIAC »
Hi,
I just open the box with the 4 axis controller and It was delivery without datasheet.
So I figure how to connect the 24V supply but I see a 5V plug...
I also read on the forum that there is no way onboard to adjust the output current
So how can we see what current is setting in?
Is there any data concerning this board?
J-P
Re: Were is the datsheet for the 4 axis board?
For now ,please review the 3-axis controller as it's almost identical, except that the 4-axis do need an 5V to poer it (dual power in this case). I'm working on the manual for the 4-axis. Thank you for your patience.
Current can be set by changing those 4 resistor on the board. For example, for 1.5A, use 0.5ohm (5watt)
CNCMANIAC
Post by CNCMANIAC »
Were is the 3 axis datasheet?
J-P ;)
