Need help to confirm Laser PSU wiring
spektrum
Post by spektrum »
Hi,
Can someone please confirm for me that the wiring in the image of my laser power supply + DSP controller is correct?
[P+ G] socket have been soldered together by the manufacturer
[K- K+] was the test fire socket
The anode is on the back of the power supply and comes from a 40w coil.
Re: Need help to confirm Laser PSU wiring
You don't connect 5V to TTL. Doing so you may set the power to FULL all the time
And, you don't connect 5V from DSP to laser power +5V. Don't d it.
I strongly not to use this kind of power supply or you may damage the DSP TTL circuit/ output easily.
spektrum
Post by spektrum »
Thanks for the response Marco. I have not connected the 5V to the TTL, I have connected the "L" from laser psu to "TTL" on the controller. Also I haven't connected the +5V from the DSP to the laser psu. Sorry I guess my diagram was not very clear.
The DSP is only connected to the p24v 5a power supply provided in your upgrade kit.
