control panel buttons on controller
The control panel buttons on my controller are no longer working. Whenever I try to cut something from lasercad my control panel shows a message on screen saying 'beyond size continue?' is there a work around for this in LaserCAD or am I SOL?
Re: control panel buttons on controller
hi there
this message comes up if there is not enough room for the laser head over swing.
there are two method to correct this:
1. move the item more to the middle or down if possible
2. reduce the speed
every time you get this message first push ESC on the panel
I hope this helps
2. reduce the speed
I hope this helps
eatingsmalls wrote:The control panel buttons on my controller are no longer working. Whenever I try to cut something from lasercad my control panel shows a message on screen saying 'beyond size continue?' is there a work around for this in LaserCAD or am I SOL?
I tried moving the object more to the middle of page, and slowed the speed down but still no dice. The message pops up on the control panel screen, but because the buttons on my control panel decided to stop working I cannot hit the esc button to bypass the message.
I am wondering if the handheld controller Marco was working on is available as a replacement that might work better for me
Thanks Aaron
Thanks Aaron
hi there
format the DSP memory then reset
check the file if there is something outside the area maybe hidden
also disconnect and reconnect the display cabel
eatingsmalls wrote:I tried moving the object more to the middle of page, and slowed the speed down but still no dice. The message pops up on the control panel screen, but because the buttons on my control panel decided to stop working I cannot hit the esc button to bypass the message.
Thanks Aaron
