1. I am using an RF Universal Laser and I am running off of Pins 1 and 3 for the modulation. Everything seems to work fine although when I power everything up the laser fires off and burns the surface then goes to the home position. Is there a way to stop this? I tried with and without pre-ignition, but it acts the same both ways.
2. Is there a top and bottom to the focus lens or can it be installed either way? I have a 55mm focal length lens from here, and was just curious. Hopefully that's not to dumb of a question..
Thanks everyone..
Chris
