I finally installed my limit switch on the Z but it does not work
(U28 side is TLP281-4)
DSP V1.2
Just to let you know - Marco is in China with only occasional access to the forum, so he may not be able to get you an answer right away.ctoutmoi wrote:Hi,
I finally installed my limit switch on the Z but it does not workThe end limits of the X and Y are working perfectly. I looked at the components of the DSP card and it's missing the U29 (above the LED U- U+ Z-Z+) I do not think it's normal?
Marco can you confirm please.
DSP V1.2
It is the same as U28. I think it is a TLP281-4 (hard to read in the photo). You should confirm by looking at your board and see what U28 (next to the open spot) is.irfanulla wrote:I have a older version too and would like to install the missing chip -macro can you tell what that is, also ctoutmoi were you able to add that chip???
Regards
Irfan
Users browsing this forum: Google [Bot] and 3 guests
