First post, This is a feature i have high interest in for the projects that i work with. While i haven't ordered this controller yet it is pretty much inevitable. Is this DSP already capable of sending the video signal via USB camera sensor, or would it require additional connections to the PC. Is the feature going to be more of an overlay style to move the work piece, or a true edge detection with origin building and skews? What i really want to know is can I just set up on a round object with the center being 0,0 with your plans, and what kind of time frame for support of this feature?Tech_Marco wrote:A feature that I want to add is capable to capture real time video and display it on the LaserCad software. What good about it? In some case where cutting or engraving were not doing right due to the power issue, with the video tracking one can re-work on it without losing the costly materials. You know, when you take the material our from the machine, it is hard to do the alignment without help from some sort of assistance.
Mike McK.
