new lasercad v. 7.09 does not show the PPI avalaible but cut
Re: new lasercad v. 7.09 does not show the PPI avalaible but
Can't be as I just done it and it worked.
There was a _temp file may be you need to delete it
hi marco
here are the printout of both softcfg files from lasercad corel and lasercad stand alone
Did you see that there is a temp file name "_Temp", delete it see if it help
hi marco
where should I look??
Tech_Marco wrote:Did you see that there is a temp file name "_Temp", delete it see if it help
CorelDraw folder where the configure file installed
no not such thing
Tech_Marco wrote:CorelDraw folder where the configure file installed
Walt, where did you find the SoftCfg.ini file in CorlDraw application at??
I did write down the list from my last , last post. Just follow it please
hi marco
under program x86 ,Corel, corel Drawgraphics , programs, and AWCCfg
everythings you wrote I have already done
Tech_Marco wrote:Walt, where did you find the SoftCfg.ini file in CorlDraw application at??
Did you delete the file "_Temp" ??
there is no _ temp file
Tech_Marco wrote:Did you delete the file "_Temp" ??
Walt, trust me, it must be there!
When you use CorelDraw to initiated LaserCad, it will create a temp file to the the "Corel" folder. See the path on the image attached.
If there is none, then I don't know what else I can do. Then, it must be your system somehow somewhere remembered the old setting.
SWMS
This issue seems to haunt a few people, maybe making two separate installations rather than an option might help in the future? Then at least someone can't accidentally install the stand alone and Corel version. So you have to ask for which version you want.
hi marco
first thanks for trying this file _Temp is nowhere on my computer, it seams to be somewhere but I don't know where.
at the moment I do it the way that I open the file from corel then save it at pwj5 and then open it with the stand alone version this works.
thanks again
thanks again
Tech_Marco wrote:Walt, trust me, it must be there!
Walt:
Give me a moment. I'll edit the original SoftCfg.ini file with the PPI enable.
thanks my friend!
Tech_Marco wrote:Walt:
