Hey guys. I'm new to this, and I could use some help.
I received this wiring diagram from lightobject: download/DSP/LaserMachineWiringDiagram2.jpg
But, its wiring is for the m415b driver, and the terminal text does not match the terminal text on the 2m656 drivers.
I was trying to "wire by the numbers" but this has thrown me and I don't want to blow anything.
Does anyone have a schematic for wiring the awc-608 controller to the 2m656?
John
Wiring the awc-608 control to the 2m656 stepper motor driver
Re: Wiring the awc-608 control to the 2m656 stepper motor dr
See AWC608 interface file I sent you. I clearly show you how to connect the stepping motor drive in general
DIR+ and PUL+ tap together and connect to DSP +5V
DIR- to DSP DIR-
PUL- to DSP PUL-
Then power the stepping motor from DC24V to 36V. That's all you need to do
DIR- to DSP DIR-
PUL- to DSP PUL-
Thank you, Marco. I don't have that file, as I purchased the kit, steppers, control board, and other components from my neighbor (who got them from you) because he didn't have the time to complete the project.
Can you tell me where I might download that file?
John
John
One other thing.
Would I be correct in assuming that on the 2m656 the "PLS" = "PUL" you mentioned in your post above?
I don't need the "ENA" terminals?
John
John
I found the interface file. Thank you. That is more clear.
John
John
