Hi guys new here,
I bought a cutter with the awc608 upgrade, after rebuilding and new wiring to tidy it up, I can run test, move all directions, and fire the laser, but if I try to cut something, I get idle in the time space and nothing moves, anyone had anything like it, or if marco could point me in the right direction,
Thanks guys for any help. Kev
Awc608 question
Re: Awc608 question
just an update, ttl as 4.4 when just sitting, if I press test fire goes to 0v, hope this helps kev
Re: Awc608 question
Check if your Cap-protection or emergency-circuit is configured properly..
It sound like the same with my machine when i had pressed the emergency-stop (which is on the top, so i could have pushed it, while laying something on top of it, or when i left the Lid / Cap open.
With older versions of the firmware you could still fire the laser manualy..
Re: Awc608 question
looks like your stepper first 3 switches are not setup correctly you can try all combos one by one till its fixed
