Where to find DSP Software ?
tonynz
Re: Where to find DSP Software ?
Thank you Marco,
I have tested, and measured directly off AWC laser output connector, running a cut and engrave,
on full power, and both sit on 4.5 v DC. No change while running or stop.
I have also found no voltage output on laser1 or laser2 PWM output either.
I can fire the Testra HV tube power supply manually with another TTL, and a PWM tester on 50% ok, so Testra HV and tube working ok.
I have now also tried connecting outputs to another standard laser machine, running a Leetro controller,
and it does not fire up the HV / reci tube in this other machine either.
I was hoping to upgrade this Leetro machine to Lightobject soon as well ).
I'm at a loss as to what to do next.
I think the AWC is not working, and cannot find, or see any other options that might hinder TTL output switching on.
Regards
Tony
Regards
Tony
Check if 'Door' protection is enabled. If so, it will disable the output
tonynz
None of those IO settings are enabled.
Water protect, Open protect, and Foot switch are all unticked.
T
T
tonynz
Hello Marco, can I begin the process to get another replacement organised asap.
After I did unsuccessful test of the LO-X7 on my Leetro laser TTL and PWM.
I decided to blow dust out from the inside of the Leetro, and its not working anymore now.
Just a random noisy beep beep beep beep...
So, I have no laser at all, and am desperate to get this one going,
then afterwards I know it goes ok, I can buy another LO-X7 to replace the Leetro too!
Please advise process,
Tony
Tony
Better not because we don know whether the problem is from the DSP card, or from something else. I think you better return the card and let us to run some tests on it
tonynz
ok, will do, where do I send it to?
I have no working laser machine at all after leetro stopped,
so will send to you by fastest way possible.
Tony
Tony
LightObject
21 Blue Sky Ct
Sacramento, CA 95828
Leave a note with order info and tell a little about what is wrong with the controller, once we received it, we will run some tests on it.
Remember that if we found nothing wrong, then you need to pay for return shipping cost. If it is defective, we will ship you a new controller card. Sounds fair?
21 Blue Sky Ct
tonynz
ok, fair, thanks.
Packing now, do you need the display part as well ?
thx
T
thx
T
Yes, the display unit actually is the main board.
tonynz
Hello Marco,
It was shipped to you and should arrive, or be there now.
Please advise what you find asap.
I should also buy another one from you urgently' at same time -
for my Leetro machine which I recently blew up by cleaning it,
and I am without an engraver laser at all now
You can email me privately at my email on your records.
thanks,
Tony
thanks,
Tony
upsetDSPowner
Need correct sw/fw for dsp e5 order209709Tech_Marco wrote:Link sent.
where to?
upsetDSPowner
still nothing
LaserCad
AWC608, X7, E5. all share the same software
I did reply you long ago through email per request
tonynz
Hello Marco,
Please advise urgent if you have received my controller for checking the ttl / pwm output.
It has been some time, you should have there, and returned back to me by now surely, but I have heard nothing.
Thank you, Tony
Thank you, Tony
Please email us for return product information. I don't handle shipping or receiving.
It is not a good idea to post your request on this thread. I will forward your question to my staff to follow up your case
