AWC-608 DSP controller what is best control software.
Posted: Sat Feb 23, 2019 2:18 am
I changed over my laser to an AWC608 DSP controller. I used lasercad for almost a year. Then when I would import a dxf everything would work great except for the engrave section. The software would change the size or location of the engraved section. I changed to a newer version of Lasercad and it got better for a little bit then started messing up again. I usually work with an image in Corel then export it out as a dxf. Then import it into Lasercad.
I downloaded Raycam, but cant get it to talk to my controller.
