z table speed adjust
lightobject z table with cohesion 3d what config files need changed cant change speed
Re: z table speed adjust
You need to contact Cohesion for setting. The Z table doesn't come with any software. It is just a Z table with a stepping motor installed. You can use a motor driver board to control it if your laser controller didn't work right
