Another conversion of K40 cutting machine with TB6560 board
I just finished a conversion for my customer "Jim" who was very patience to wait for the project to be completed. A two axis TB6560 motor board is used and it runs great on Mach3
See video:
See video:
Re: Another conversion of K40 cutting machine with TB6560 bo
Looks nice! As a bonus I finally got to see how someone wired their emergency kill switch. ![Confused :?](./images/smilies/icon_e_confused.gif)
Hi all,
Marco, this board can it be used for engraving aswell as for cutting an how is the laser fire triggered.
I feel more comfitable with Mach3. Caroldraw can't open DXF files.
Neil
Neil
hi neil
you are wrong I open DXF files all the time directly in CorelDraw.
Kiwi53 wrote:Hi all,
Neil
Hi waltfl,
ok then something is wrong with my coreldraw, just checked which file I was talking about an it is a dxf file.
I went into draw an tried it as an open file, no reconise the file, tyhen tried import same thing so something is amiss.
Hope this file worked:- Please try to open it an post the image here. If it works in opening into coreldraw then
there is something wrong with my settings. Runnung x6 coreldraw atm.
Neil
ps:- main thing I like to know is can the TB6560 board able to engrave aswell as cut?
Neil
- 260_clean.dxf
- (286.83 KiB) Downloaded 235 times
There are many types of DXF files, some open some do not. A older version that works for me is AutoCAD Release 14. From there you can try newer versions.Kiwi53 wrote:Hi waltfl,
Neil
I opened fine for me in Corel X6, you need to start a New drawing and make the settings either metric or US inches and then Import. Came right in, I did my New drawing in Metric which I use because my laser engraver is Metric.
hi neil
no problem see attached screen shot
Neil
- testopendxf.pdf
- (244.29 KiB) Downloaded 248 times
Hi waltfl,
Thanks it is what it should be, I see that you run X5, I'm running X6.
Hi wmgeorge,
I'll retry it in new draw an set to Metric an import to see if that works
Thanks you two
Neil
Hi wmgeorge,
Thanks you two
Neil
Hi,
Ok took screen shots of the dxf file, first is new draw setup, the second is import drawing.
Hi all,
Thanks for the insite for the dxf file, coreldraw does not handle it, just coverted it to AI file the imported to coreldraw.
Now back to my original Q
Neil
still like to know, this will leave me an option later.Kiwi53 wrote:Hi all,
Neil
Neil
Resurrecting an old thread....
Marco, Were you able to use the stock optical switches with this conversion? If so would you share how this was done? My new K40 has the ribbon cable for the switches. Thanks, Doug.
