JLD612 wiring update...see if it's right?
Posted: Mon Apr 04, 2011 3:58 pm
by robinhood
Just wanted to make sure that it's wired correctly now...
my JLD612 with SSR wiring.pdf
Re: JLD612 wiring update...see if it's right?
Posted: Mon Apr 04, 2011 7:44 pm
by richiem
Looks OK to me.
Posted: Mon Apr 04, 2011 7:46 pm
by robinhood
Thanks very much richiem! will give it a go.,..
Posted: Thu Apr 21, 2011 5:20 pm
by chutney
thanks for putting up your drawing it helped me to lay things out right. The one thing I noticed is you put a fuse in the neutral back to the JLD612 post 2. I would never put a fuse in the neutral because you break the flow of power back to the box and you should only break the hot/positive. I finished my build last night and I'm running another test tonight.
