coresponding mA to % in the new DSP
Posted: Tue Jan 03, 2012 1:25 pm
by waltfl
Hi
I just finished the measurments to find the corresponding mA to the % settings in the DSP
% = mA
8 2 usually start laser working
9 3
10 4
20 8
30 10
40 11
50 12
60 14
70 15
80 16
90 18
just in case somebody did wondering how it converts.
Re: coresponding mA to % in the new DSP
Posted: Tue Jan 03, 2012 1:26 pm
Very good work Walt!
Posted: Tue Jan 03, 2012 1:46 pm
by twehr
waltfl wrote:Hi
% = mA
9 3
10 4
20 8
30 10
40 11
50 12
60 14
70 15
80 16
90 18
Those figures are only good for your specific machine. PS vary greatly. For me, 58% (PWM) = 18 mA at the tube.
EVERYONE needs to run the tests for their own machines!
Posted: Tue Jan 03, 2012 2:13 pm
by Gadroc
I'll re-emphasize Tim's statement that this is very dependent on your machine and wiring. I have a nearly identical machine to Walt's. If I took a picture of my power supply you would not be able to tell it from his, but mine hits 15ma at the tube at only 32% output from the DSP 2012 board.
Everyone should generate their own chart starting low end first. It may surprise you how fast it ramps up.
Posted: Tue Jan 03, 2012 2:24 pm
by waltfl
Hi you guys
I give up you guys allways need to be right
My PS is the PWM PS from marco and the DSP AW 608 with lasercut 5.77
I believe there are enough guys out there who would like to know even if it is just some rough idea
Gadroc wrote:I'll re-emphasize Tim's statement that this is very dependent on your machine and wiring. I have a nearly identical machine to Walt's. If I took a picture of my power supply you would not be able to tell it from his, but mine hits 15ma at the tube at only 32% output from the DSP 2012 board.
Posted: Wed Jan 04, 2012 6:29 am
by Gadroc
That wasn't meant to be offensive or be right. Your info is good for comparison, but if I had read that info and took it at face value when I first got mine running I'd probably have blown my laser tube by now.
Posted: Wed Jan 04, 2012 6:41 am
by twehr
waltfl wrote:Hi you guys
It is not a matter of being right. It is a matter of helping people prevent unnecessary damage to their tubes by not knowing all the information they need to make a well informed decision.
If that bothers you, I suggest you simply skip over our posts.
