Pro 25mm beam combiner
Posted: Sun Aug 14, 2016 11:43 am
by GeneMpls
Marco- I see that you have stock on the beam combiner again- can I position this right out of the 1st mirror- that is where I have room for it. Thanks
Gene
Re: Pro 25mm beam combiner
Posted: Sun Aug 14, 2016 6:15 pm
Hey Gene:
Yes you can. The new combiner is a fixed version. It should work better on the beam alignment issue happened with beam expander.
(in China)
Posted: Mon Aug 15, 2016 7:44 am
by GeneMpls
Marco- one last question before I order- my laser is 130w- this 25mm lens will be OK with that, right? Thanks Gene
Posted: Mon Aug 15, 2016 5:27 pm
It depends on the size of the laser beam spot. So, you need to measure the beam size.
Maeco
Posted: Fri Aug 19, 2016 7:45 am
by GeneMpls
I am getting 7.55mm an inch away from the tube (before the first mirror) thanks Gene
Posted: Fri Aug 19, 2016 9:20 am
I suggest 1.5X beam expander. 2.0X may be too big for regular machine. If you have 7.55mm beam diameter, you may get 12~14mm diameter right before the inlet hole from the laser head. If you get 2.0x, you may get 16~18mm beam diameter. I think it is just too big for 25mm reflection mirror for for a common laser head.
Posted: Fri Aug 19, 2016 10:32 am
by GeneMpls
Marco- I get 8.6mm at the farthest corner of the machine (1300x900) at the cutting head. I am not sure what a beam expander does or where it goes.
gene
Posted: Fri Aug 19, 2016 5:37 pm
Hi Gene
Discard my last post because I thought you wanted to use an beam expander. You are good to go
(Training in China)
