Cooling 45w tube w/ 50mm radiator
Posted: Mon Oct 05, 2015 4:16 pm
Greetings,
I purchased the 50CM radiator, 20L pump and fan to cool my 45w. I had a few questions.
Is it enough to run it as a closed system with the SP 45w tube? Would I need an additional reservoir?
In my last setup (5gallon bucket and fountain pump), i eventually got some bacterial growth (presumably. white, cloudy, yuck). I believe this didn't help my last tube which I'm replacing. Is there any sort of antibacterial that is safe? is closed loop with distilled water ok? do you have to flush perodically?
tell me more!
tell me more!
