60W Laser tube weak and power drop after few cut
Posted: Tue Jun 30, 2015 8:59 pm
Recently, I finish my new diy laser cutter.
The setup info as below:
AWC608 controller
60W glass tube
60W power supply from my old Chinese laser
CW3000 water chiller
The tube is pretty new, I think it worked below 50hrs
Even this tube installed in my old machine, the power % needed to be set higher than the oldest one.
After I put the tube and PS to my new laser with the awc608 card, the power is even lower.
It barely cut 3mm acrylic in 80/50% in 6mm/s.
After a few cut, the power dropped and it cannot cut through even I set it at slower speed.
There are few thought of mine.
Is the power supply doesn't fit the tube or it is almost broken?
Secondly, I know the temperature is another reason to make the cutting power dropped and the CW3000 is air cooled only.
The meter of the CW3000 always starts at 30degree. I am not sure it show the temperature of the tube but it works fine when I am using my oldest 60W tube.
Thirdly, is there any settings on Lasercad wrong? I set the frequency at 20000, except this, anything needed to be set?
Roy
AWC608 controller
60W glass tube
Roy
