Really Dim Temp Gauge?!
Posted: Thu Feb 19, 2015 10:40 am
by thejuggernaut
Is anyone using one of these?
http://www.lightobject.com/Mini-Digital ... -P421.aspx
I hooked it up and I can barely read it. The photo on the site looks like it is back lit, but mine seems to be very dark. I pushed the little click button on the back and all it does is change it from F to C. Am I missing something or is mine faulty?
Re: Really Dim Temp Gauge?!
Posted: Thu Feb 19, 2015 5:27 pm
by AndyKunz
Mine is like that too. It needs to be looked straight-on. The problem is that it's a "3 o'clock view" and should be "6 o'clock view" LCD panel, I think.
Andy
Posted: Thu Feb 19, 2015 5:38 pm
by thejuggernaut
Dang,
Cause on the website it looks nice and bright! I may try to find a different one.
Posted: Thu Feb 19, 2015 5:47 pm
What voltage you used?
Posted: Thu Feb 19, 2015 5:52 pm
by thejuggernaut
5V DC
Posted: Thu Feb 19, 2015 5:54 pm
by thejuggernaut
I have 5v, 12v, 24v, 36v and 120v to choose from, so if higher voltage works better, I can do that.
Posted: Thu Feb 19, 2015 6:45 pm
I would say 5V is bright enough to see well, even though it is not very bright. Post a picture let me see how dim it is. It could be defective
Posted: Thu Feb 19, 2015 8:34 pm
by thejuggernaut
The first photo is with the camera flash.
The second photo is with overhead lights.
Obviously, it's powered up in both photos.
Posted: Fri Feb 20, 2015 5:23 pm
by thejuggernaut
I guess Marco still isn't feeling well. Andy, is yours as dim as the one I showed in the photo?
Posted: Fri Feb 20, 2015 5:44 pm
by AndyKunz
In normal light mine looks about like your flash picture (not quite as bright, but close).
Posted: Fri Feb 20, 2015 5:45 pm
by thejuggernaut
Yea, I think mine is broken.
Posted: Wed Feb 25, 2015 6:24 am
by thejuggernaut
Did you look at the photos? Does it look defective?
Posted: Fri Mar 06, 2015 11:45 am
Did you receive a replacement from us yet?
Posted: Mon Mar 09, 2015 9:59 pm
by thejuggernaut
Not yet,
I need to send you the old one back along with the pump you replaced as well. I have them in the box, just haven't sent them in.
