Where to find DSP Software ?
ukanduit
Re: Where to find DSP Software ?
There is no link to download the patch. It says: "You do not have the required permissions to view the files attached to this post."
You should logout and login again see if the links appear or not
Your account was activated and I see no reason why couldn't you open the link
I found no issue when I login to your account and tested the permission.ukanduit wrote:There is no link to download the patch. It says: "You do not have the required permissions to view the files attached to this post."
SWMS
Will this firmare work with the original AWC608?
jairogj
Hey Marco,
Please send me a link to the updated software and manual and drivers (w10, xp 32 and 64bis)
Order Date: 12/21/2012
Order Number: 195099
Ship To: Jairo Gabardo junior
Thank you
Thank you
metzench
@jairogj Already tried this too, no answer to emails and so on... Really disappointing. Mine was bought 2013...
Already posted all update on the download site on this site. Just a couple click and you can get it.You can just make a click to get it.
Remember that the software support last for 1 year only. It is customer responsibility to get an update frequently before the card is getting out of date.
metzench
@Tech_Marco
What means software support only for one year? LaserCad Versions still work and the firmware updates too right?
Could you please explain this?
Besides that this was new for me.... Sometimes just answering emails would be nice to have such things explained. Just not answering is not really targeting. And this really makes the difference when deciding to buy another one....
don_kleinschnitz
I am seriously considering upgrading my K40 with your high end DSP.
Before I do I want to kick the tires on the software which I assume is LaserCad to insure that it will do what I need?
Can I get an eval copy or at least the manual?
Also is LaserCad and RDworks the same software?
@Don, the link for the laserCad is available download from the download area. LaserCad is Not a mini or inferior version of RDWork that a few people thought it was by mistake.
don_kleinschnitz
Thanks Marco I found the software and will look at it.
OzAdr1an
Can I have my permissions updated for the DSP Controller firmware/download section ?
Order Date: 5/9/2016
Order Number: 209265
Thanks Marco
Thanks Marco
tonynz
Hello Marco,
I cannot get the TTL signal to operate the laser, nor the PWM signal, maybe an upgrade will help? Please send me details too, thanks. routercut at clear.net.nz. inv#123954B (April01 2016).
I don't have any update in the mean time. I do not believe that it has anything to do with the firmware in yoir case. I think you need to check the connection. If not, it is possible you may have hardware failure either on the control card (odd) or bad pwm circuitry on the laser power supply.
