Page 2 of 15
Re: Converting K40IV machine
Posted: Mon Jul 18, 2011 5:12 am
by twehr
TeacDance wrote:Now all connected but some problem i have
how i can go change the parameters? i put phcad password but always it say password error!
is password change?
other problem is limit switch
What password are you using? The correct one is
ph123
Posted: Mon Jul 18, 2011 5:33 am
by TeacDance
twehr wrote:TeacDance wrote:Now all connected but some problem i have
is password change?
ph123
Thaxs that workin i try wron
gxfc88
do you have limit switch diagram now i when i push switch led go on is that correct?? when i drive home motor not stop? what my connet wrong?
Posted: Mon Jul 18, 2011 11:55 am
by TeacDance
TeacDance wrote:twehr wrote:TeacDance wrote:Now all connected but some problem i have
is password change?
ph123
gxfc88
Yeppii now limits working next laser
Posted: Fri Jul 22, 2011 3:00 pm
by TeacDance
TeacDance wrote:TeacDance wrote:twehr wrote:TeacDance wrote:Now all connected but some problem i have
is password change?
ph123
gxfc88
Now all working allmoust right
only arrow direction is wrong but if i change direction my reset direction change same is that bossible change some another way?
Posted: Mon Jul 25, 2011 6:17 am
by TeacDance
Couple pictures of my conversion... do i have to use that big resistor look picture 1567 right side??? now it's not use but it's working
Posted: Wed Jul 27, 2011 3:21 am
by TeacDance
TeacDance wrote:Couple pictures of my conversion... do i have to use that big resistor look picture 1567 right side??? now it's not use but it's working
anybody know that resistor?
Posted: Wed Jul 27, 2011 4:55 am
by twehr
TeacDance wrote:TeacDance wrote:Couple pictures of my conversion... do i have to use that big resistor look picture 1567 right side??? now it's not use but it's working
That was part of your original power for the laser tube. Don't need it with standard laser power supplies (like the ones from LightObject and other sources). Take it out and forget it.
Posted: Wed Jul 27, 2011 9:27 am
by TeacDance
twehr wrote:TeacDance wrote:TeacDance wrote:Couple pictures of my conversion... do i have to use that big resistor look picture 1567 right side??? now it's not use but it's working
Ok..
Posted: Thu Jul 28, 2011 3:02 pm
by TeacDance
Hmm is possible to use phcad without machine?? It's say Connect machine "OK" and "CANCEL"
Posted: Fri Jul 29, 2011 4:27 am
by TeacDance
What meaning when laser display say " Not enough extend space please esc"
Posted: Fri Jul 29, 2011 4:59 am
by twehr
TeacDance wrote:What meaning when laser display say " Not enough extend space please esc"
Means you are too close to the edge of your useable work area for the speed you are wanting to engrave. To engrave, it takes extra space before and after the x sweep to get up to speed. Move your origin so you have more room to left and right of engraved area.
Also, you can increase your acceleration speed. The faster the acceleration, the less room necessary to get up to speed. Acceleration speed should be in the 8000 mm/s/s range. If you are already there, move your origin so there is room to left and right of engraved area.
See my original post and diagram on this subject:
viewtopic.php?f=8&t=277#p654
Posted: Fri Jul 29, 2011 12:40 pm
by TeacDance
Ok that is my problem but now it's solved
Today i made new control panel holder my wood router here is couple pictures
Posted: Sat Jul 30, 2011 1:44 pm
by TeacDance
Today i do 30 pcs customer job and earn little cash back
First cut wood router basic instrument base and next burn laser detail. meter use in sauna
Posted: Sat Jul 30, 2011 1:50 pm
I'm so glad to see that the DSP is working. Great job!
May I ask you a favor. Since so many folks bought this D40 machine and having trouble with it's own software. Many of those folks want to upgrade by installing my DSP. Would you you post the parameters setting here like the pulse, steps, bed size... I'm sure the motor is identical as this D40 was made by ShenHui in China. As matter of fact, I'm testing a card with the D40 X,Y motor rack.
Thank you
Posted: Sat Jul 30, 2011 1:53 pm
One more thing, please post the wire diagram to the TB6560 driver and the Limit switch as well
Cheers!
