Aluminum frame/ case for CO2 laser machine
Axeman
Re: Aluminum frame/ case for CO2 laser machine
Post by Axeman »
That's great news! The power table that I would be looking for would only be for the 960 or 1290...
Good good. 3 months I can wait for, I'd prefer a power table if I'm going to go whole hog down the road.
Whiteylightning
Post by Whiteylightning »
I am interested in these, but how much floor space do they occupy?
Whiteylightning wrote:I am interested in these, but how much floor space do they occupy?
You mean the frame? If so, what size?
My shipment arrived with delay. It is currently still being hold at Oakland as truck driver has hard time to pick it up. Possible pretest by workers there per freight company
They said that it should delivery to me on Feb 28th. Once I have it, I'll assembly all size for demo
Updated: shipment arrived. Just found that the frame for 1200x900 is very, very, very heavy! I believe it is over 250#. It damage our scale (330#) when we tried to measure the true weight. I need to buy a new digital scale and do again :cry:
intelinc
Post by intelinc »
Is the putative z-table an upgrade that can be applied to the current 640 frame, or is the frame itself being redesigned to accommodate this functionality? Thanks!
Ryan
Hello Ryan:
We tried to make it compatible to be compatible to our frames (not important as it is adjustable to some extend). The main things is the honeycomb and that is something we take it into account when we're designing the power 'Z' table now
A prototype power 'Z' table for 640 system should be ready in about 3~4 weeks. Once we received it, we can do improvement if necessary based on the prototype. It is 'a pair of dual scissor' type just let you know in advance
intelinc
Post by intelinc »
Tech_Marco wrote:Hello Ryan:
Thanks Marco. So if I understand you correctly, the new power z table will be sold as an add-on feature compatible with the current frame you sell. I just wanted to make sure that if I started a build now, I could take advantage of the power z table without having to purchase a new frame. Thanks!
Ryan
Ryan, the power Z table is gonna to be universal and it will fit our frame for sure. Otherwise it make no sens to sell things that not compatible to each other. We try to be compromise on the design and make it easy to be used on other machine as well.
By the way, I have two power Z table (sample) here as well. It is heavy duty (steel made) but it wasn't a designed to be compatible with the current model of body frame. It is just two samples we ordered wanting to sell in US. It is very very heavy but you guy must like it as it works flawless and very powerful. I was told that it could lift up 100lb but not sure that as I haven't tested it my self. I'll take some picture to show in a moment.
swamidog
Post by swamidog »
i can't wait! power-z and autofocus would be so handy.
Tech_Marco wrote:Ryan, the power Z table is gonna to be universal and it will fit our frame for sure. Otherwise it make no sens to sell things that not compatible to each other. We try to be compromise on the design and make it easy to be used on other machine as well.
By the way, I have two power Z table (sample) here as well. It is heavy duty (steel made) but it wasn't a design to be compatble with the current model frame. It is just two sample we ordered and want to sell in US. It is very very heavy but you guy must like it as it works flawless and very strong. I'll take some picture to show.
Following is a standard power Z table sample we received from a tooling company who can mass production for us for resale.
It is made of stainless steel with high torque "86" series motor. Picture is showing the model of 600x400 and we have 900x600 as well.
Folks, take a look of this: viewtopic.php?f=46&t=2025
