LO Pro530 user paramenters
Carlosbarraza
Post by Carlosbarraza »
hey marco
I have a pr 530 and e5 controller and was wondering if i could get a copy of the user and manufacturer parameters. I was wanting to use the as a reference point for adjustments.
thanks carlos
Re: LO Pro530 user paramenters
Hey Carol
Parameters foe th PR530 is preset into.the card. Unless you changed it, you can use the software to export.the Parameters for backup
Carlosbarraza
I do have a copy backed up from the e5 but as I purchased the 530 gantry first and built my machine then bought the e5 later. I was wondering if the e5 I purchased is still set for the pr530 gantry. I had to change the range and um/pulse so this is why I was thinking it was not set up to the pr530 gantry and why I was requesting the settings
thanks
carlos
yurirage
Post by yurirage »
The answer to this question would actually be very helpful to anyone who purchased a PR530 X-Y stage. Through a bit of trial and error, I've got a workable set of parameters, but I'm curious to know the factory settings for the turnkey machine.
Return to “LO PR530 Desktop laser machine”
