Latest Firnware for Lo-X7
Posted: Fri Nov 08, 2019 10:58 pm
by smgvbest
Hi
I have a DSP LO-X7 (AWC708C Lite) currently on Version 1.16.12.10(LO)
Last file I had for upgrade was 161210LO.UG5
is there a newer version of the firmware available?
Thank you
Sandra
Re: Latest Firnware for Lo-X7
Posted: Wed Jan 08, 2020 2:40 am
by CortezK
Have you checked the download pages for that model, Sandra?
Posted: Thu May 07, 2020 8:04 pm
by smgvbest
Yes, none will load
Posted: Sat Nov 12, 2022 6:20 pm
by lawrencejeff
I have the same firmware on mine and am looking for an upgrade- did you find the correct one?
I see the RAR file in the downloads and I can download it but the text says for controllers only running lasercad. Mine works with Raycam and I thought you had to have it sent in to make it work with lasercad
Can anyone confirm if one running the LO firmware can upgrade to the one here
https://www.lightobject.info/viewtopic.php?f=55&t=4133?
I don't care about lasercad or raycam - I use lightburn
Want to upgrade the firmware as I am seeing some weird things on the Z axis
