Laser not firing - bad board?
Posted: Sun Feb 07, 2016 12:53 pm
Just bought the x7 DSP to control my laser cutter. Everything seems to be working except the laser will not fire from the DSP. My power supply has H,L, WP, IN 5V connections.
Here's my wiring from the DSP to the LPSU:
PWM to IN
G to G
TTL to TL (set to low level in laser cad)
On the power supply itself, I have WP jumped to ground. Pressing the laser button or running files on DSP doesn't fire the laser but I can manually fire the laser with a test switch on the PSU. To troubleshoot, I checked voltages between the laser output pins on the DSP as well as tried switching the connector to the laser output 2. Here's the voltages across those pins which remain constant regardless if I use DSP's laser button or am running a file:
TTL to ground: 4.85V
PWM to Ground: 0.00V
TTL to PWM: 4.85V
I really hope I'm just missing a setting somewhere!
PWM to IN
G to G
TTL to PWM: 4.85V
