Windows 10 error installing CorelDraw plug in
Posted: Sun Aug 09, 2015 12:08 am
by SWMS
Hi, guys, I am running a test build with windows 10, I have LaserCad 7.6 installed with Corel Draw x6 64bit.
When I try to install the plugin it says :
Cant find Coreldraw
If I try to manually direct it to
c:\program files\corel
it says the path is error!
Help please
Re: Windows 10 error installing CorelDraw plug in
Posted: Mon Aug 10, 2015 2:15 pm
I talked to the programmer and he said that he should work. But there is a procedure you should follow. I got to check the manual and see 'how to'. Will post back later when I found it.
Posted: Thu Aug 27, 2015 11:24 am
by spierce
Have you found a solution to this issue? I'm trying to install LaserCAD 7.65B on Windows 7 and CorelDraw x6 and I'm getting the same error.
Scott
Posted: Thu Aug 27, 2015 11:32 am
He said that it would work. What you need to do is to do it manually.
Run the LaserCad, select "Plugin For CorelDraw"
Click Install
Uncheck "Auto to Install"
Select Coreldraw version, in your case, it is Coreldraw X6(64bit)
Click Browse and find the path for the CorelDraw folder. Since you have 64bit version, the CorelDraw folder should be located in the "Program Files". As opposite that if you have 32bit CorelDraw, you should select "Program Files (x86)
Click Corel folder
Click CorelDraw Graphics Suite X6 and high-lighted it. Do not select the subfolder
Click OK
It should work. I installed it on my X7 and it worked
Posted: Thu Aug 27, 2015 4:19 pm
by spierce
Thanks Marco,
I could have sworn that I did those exact steps 5 times before posting in this forum without success....but now that I tried it one more time after you posted, it worked!
Posted: Fri Aug 28, 2015 2:52 pm
I tried the steps as shown
I was not able to get this plugin to work.
I am installing on CorelDraw X6
I get the following.
Posted: Fri Aug 28, 2015 3:06 pm
Do not highlight subfolder or file.
Please read my previous post again
Posted: Sat Aug 29, 2015 6:39 am
As you can see by the screen shots I highlighted the "CorelDraw X6" directory (under the "Program Files (x86)\Corel" directory)
Does not work.
So I tried highlighting the "Corel" directory under the Program Files (x86) directory.
Does not work
So I tried highlighting the Program Files (x86) directory.
Does not work.
I was never able to make this work.
Not in Windows 7
Not in Windows 8
Not in Windows 8.1
and Not in Windows 10
Each time you release a new version of LaserCad I hope and cross my fingers that the bug gets fixed,
Here's hoping that it gets fixed in 7.66B if not then maybe 7.67B or .......
Thanks for trying
Larry
Posted: Sat Aug 29, 2015 9:05 am
Larry
Your Core application seems different than a standard one.
Ours is "CorelDraw Graphics Suite X6 "
But yours "CorelDraw Essential"
I think that was the cause
Posted: Mon Jun 27, 2016 4:29 pm
by carso2186
i was triying to install the plugin in coreldraw x7 on with windows 7 and i have the same error... does any one found the solution?
