4-Axis or 6-Axis Controller?
Posted: Wed Feb 12, 2020 5:00 am
Laser can be used in many different ways for many different applications. In my case, I am interested in laser engraving (not necessarily cutting) surfaces (quickly) for my business (awards and trophy shop).
Too that end, I have a use for a rotary attachment option. On my current (preparatory) machine, when we insert the rotary attachment, it "plugs in" and informs the software that the attachment is present and moves the (Z) gantry to a predetermined location that relates to the “center” of the rotational device. This then “switches” the “Z” axis control to the rotation device and that “Z” movement operates the rotation device. (At least this is my perception of what is happening.) The “X” axis ‘rasters’ across the object being engraved and the “Z” axis now rotates the object being engraved to create the desired result.
Now, having established this example activity, I am trying to determine which controller I need to first control the the rotational device (like a “Traction Rotary for CNC or CO2 Laser Machine”, Lightobject sku ECNC-RTY4W).
My question, I am seeing 4 axis controller that have a axis “U” but I am not finding any documentation that references using “axis U” controller for a rotary device. Generally, I find docs that reference “axis U” for table roller movement.
What I find is forum posts of various users that are psychically “unplugging” their “Z axis motor wires” and plugging in the rotary to the “Z axis” to control the rotation. I would prefer to not unplug and plug the device “in this manner”.
So, my question, finally, (sorry for length of post) can I use the “Axis U” controller to control the rotary attachment? Or would a 6 axis controller (like a X7?) be better and use the fifth or sixth axis (“V”? or “W”?) to control the rotary?
Once someone helps me determine which controller I need (4-Axis or 6-Axis) for this activity, then I can dig into the appropriate user manual see how to accomplish this somewhat complicated task and ask more specific rotational questions, here.
Thanks in advance.
Thanks in advance.
